I am not able to edit the AfterConnect.sql file in the installation folder of my work computer. I have tried modifying the file that exists in my "%AppData%\PLSQL Developer 15" folder but it does not get executed. My assumption is that the software has been installed for the current user so the %AppData% folder may not be referenced as it does in our Citrix-type environment. I have also tried suggestions mentioned in other threads. I have tried setting the Directories for Command file and SQL scripts under Preferences but neither of those appeared to work. I have also tried checking the settings for ORACLE_PATH and SQLPATH but neither of those folders are accessible to me.
Is there a search path the application uses when attempting locate the AfterConnect.sql file? If so, that may allow me to place the AfterConnect.sql file in a different location.
