Brian Baker
I am using the VCS add-in for PLSQL Developer 6 along with Visual SourceSafe. I have the VCS preferences of Allow version control over DB objects and Add Spec and Body as a Single file enabled. However, only the spec or body (not both) is added.
If I go to the PLSQL Dev preferences > Oracle > Options and check Allow editing of databaase source it will work correctly. However, I do not want to have this option enabled as I want to ensure that the developers are only making changes to the database objects by checking the code out of VSS.
