Access Violation while Doubleclick to open Spec & Body
After working with an instance of the PLSQL Developer for a while, I sometimes get an error "Access violation at adress XXX. Write of adress YYY". This happens, when I doubleclick on an object, to open the Specification and Body. I work with PLSQL Developer in version 10.0.5, but this error also happened in version 10.0.2.
After this error occurs, I have to restart PLSQL Developer to continue my work.
No, there a plsqldev.elf file was not mentioned. But I found one way (I think there are quite more) to reproduce the error. After opening the specification & Body on one database, change the database. Try to open specification & body of the same object or an object with the same name again and the error occurs.
Hi Marco,
with the same error I got a .elf file.
Just mailed the file to you.
Kind Regards
Nis
I have the same problem, consistently reproducible. Open a package by double-clicking in one database instance, then log into another instance (single connection only, not using multiple connection option) with the package still open in the editor. Double-click the same package from the object tree in the new instance. Crash.
