About dbms_trace data analysis in test window
Albert
Hello!
When we go to a trace tab after execution of the statement we can see that PSD runs such query for EVERY line of trace (table plsql_trace_events):
SQL:
select text from sys.dba_source
where type = :unit_type
and owner = :unit_owner
and name = :unit_name
and line = :unit_line
It is extremally slow
Thank you
Hello, Marco
I've send the debug file to the mailbox support@allroundautomations.com
in addition
Such behaviour we can see in case of code profiling too (see trace file)
Thank you
