A small, but useful enhancement
Helene
In the SQL window, you can export the query result in different formats. This is a nice feature. However, I would like to have a question pop up when the file is stored, that enables me to immediately open the file.
Most of the time I need the exported file right away. This should be easy to fix :)
WIth regards, Helene
Hi!
One addition, it would be nice, if table export doesn't rely on "Browse filters"...
I've set up browse filter for my current project, so I can get narrow list of tables, packages etc., but I need to export data from table that doesn't fit into my filter. So i right click on table name , export and I'm not getting that table exported, because it's not on the list, and if you accidentally press export button, there it goes, all tables in the list are being exported, that is not good...
