A few minor PSDx64 Issues
jking
I have PSD (11.0.4.1174) and PSDx64 (11.0.4.1788) installed in separate folders running on Win8.1
Issues
1) When I copy/paste the SQL into MS Word, the background color of the SQL window is copied with the text. The image below shows what the SQL looks like when it gets pasted. The top is the normal PSD and the bottom 3 are from PSDx64 using a SQL Window background color shades of yellow, blue and red.
I can change the Paste to do "Text-Only" but don't need to do this in normal PSD.
2) In PSDx64, the date formats in the result grids are shown with a 24-Hour time. In normal PSD, it is correctly showing 12-Hour time:
PSD: "1/5/2016 4:05:34 PM"
x64: "1/5/2016 16:05:55"
Both versions have "Windows format" in the NLS Options.
3) When exporting to Excel 2013, the Excel window that is opened is using different Fonts:
PSD: "Calibri"
x64: "Microsoft Sans Serif"
Is there a setting to change this?
Joe
Marco,
Thanks for fixing item 1 (from original post above).
Any chance you get get items 2 and 3 corrected in the next version. It's getting annoying to have to manually correct the format and fonts. I sometimes prefer to just use the 32 bit version of PSD to not have to deal with it.
Thanks.
