8.0.3.1510 crashes at startup with Access violation in module ntdll.dlll
jimmo
Greetings!
We are running PL/SQL Developer Version 8.0.3.1510 on Windows 2008 Server SP1 on VMWare. Sometimes when it starts, right after we input the login data, we get error messages like this:
Access violation at address 77E43DE4 in module ntdll.dll.
the address differs each time and we can login several times before the problem occurs again. I cannot see any pattern as to when this occurs. (e.g. only specific users or only specific databases)
I have googled and found several references to acccess violations in ntdll.dll and the cause mentioned is either a bug in the application (pl/sql developer in our case) or filesystem corruption. In the "PL/SQL Developer - News" I found nothing to indicate that this is a known bug.
An info or suggestions on how to correct this would be appreciated.
Regards,
jimmo
Here is the contents of the debug.txt. Thank you very much for your assistance.
Regards,
jimmo
PL/SQL Developer
Version 8.0.3.1510
Physical memory : 4.193.848 kB (1.801.856 available)
Paging file : 4.194.304 kB (4.194.304 available)
Virtual memory : 2.097.024 kB (1.975.420 available)
Parameters
C:\Program Files (x86)\PLSQL Developer\plsqldev.exe
DebugSQL
Preferences
Session mode: Multi
OCI Library:
Use OCI7: False
Preference Files
Plug-Ins
06.02.2012 09:25:17 Application started
06.02.2012 09:25:17 InitPreferences
06.02.2012 09:25:17 Load C:\Program Files (x86)\PLSQL Developer\Preferences\Default = 0
06.02.2012 09:25:17 PreferenceSet.Load C:\Program Files (x86)\PLSQL Developer\Preferences\Default\Default.ini
06.02.2012 09:25:17 PreferenceSet.Load OK
06.02.2012 09:25:17 Determine LocalPrefPath
06.02.2012 09:25:17 [1]: C:\Users\jammoh12035\AppData\Roaming\PLSQL Developer\Preferences
06.02.2012 09:25:17 LocalPrefPath: C:\Users\jammoh12035\AppData\Roaming\PLSQL Developer\Preferences\jammoh12035
06.02.2012 09:25:17 Load C:\Users\jammoh12035\AppData\Roaming\PLSQL Developer\Preferences\jammoh12035 = 0
06.02.2012 09:25:17 PreferenceSet.Load C:\Users\jammoh12035\AppData\Roaming\PLSQL Developer\Preferences\jammoh12035\default.ini
06.02.2012 09:25:18 PreferenceSet.Load OK
06.02.2012 09:25:18 PreferenceSet.Load C:\Users\jammoh12035\AppData\Roaming\PLSQL Developer\Preferences\jammoh12035\user.prefs
06.02.2012 09:25:18 InitPreferences end
06.02.2012 09:25:18 SortPreferenceSets
06.02.2012 09:25:18 - Default jammoh12035
06.02.2012 09:25:18 - System Default
06.02.2012 09:25:18 pfReadRegistry(PL/SQL Developer\Shell\Open\Command, )
06.02.2012 09:25:18 ReadString OK
06.02.2012 09:25:18 pfReadRegistry: "C:\Program Files (x86)\PLSQL Developer\PLSQLDev.exe" "%1"
06.02.2012 09:25:18 LoadPreferences
06.02.2012 09:25:18 LoadPreferences searching for default
06.02.2012 09:25:18 C:\Users\jammoh12035\AppData\Roaming\PLSQL Developer\Preferences\jammoh12035\default.ini
06.02.2012 09:25:18 LoadPreferences NewPref := nil
06.02.2012 09:25:18 LoadPreferences Reading preferences
06.02.2012 09:25:18 LoadPreferences ReadPosition
06.02.2012 09:25:18 LoadPreferences ToolsBrowserItemClick(nil)
06.02.2012 09:25:18 LoadPreferences CreateBrowserFilters...
06.02.2012 09:25:18 LoadPreferences Files
06.02.2012 09:25:18 LoadPreferences Logon
06.02.2012 09:25:18 LoadPreferences Buttons
06.02.2012 09:25:18 LoadPreferences Printer
06.02.2012 09:25:18 LoadPreferences FileBrowserFolders
06.02.2012 09:25:18 LoadPreferences BrowserFolders
06.02.2012 09:25:18 LoadPreferences end
06.02.2012 09:25:18 MacroLibFilename: C:\Program Files (x86)\PLSQL Developer\Macro\jammoh12035.emlib
06.02.2012 09:25:18 FormCreate Logon.Execute
06.02.2012 09:25:20 TOracleSession PLSQLDevForm.Session Start Session.LogOn as support@fodbi3-test
06.02.2012 09:25:20 TOracleSession PLSQLDevForm.Session End
Result = Access violation at address 77E43E0D in module 'ntdll.dll'. Read of address 013CBDFA
Duration = 0,015
06.02.2012 09:25:27 LogonHistorySave start
06.02.2012 09:25:27 ChangeUserPref LogonHistory,
06.02.2012 09:25:27 ChangeUserPref DSA,
06.02.2012 09:25:27 ChangeUserPref end
06.02.2012 09:25:27 ChangeUserPref ColumnAssociations,
06.02.2012 09:25:27 ChangeUserPref ImportAssociations,
06.02.2012 09:25:27 ChangeUserPref BrowserFilters,
06.02.2012 09:25:27 ChangeUserPref FileBrowserFolders,
06.02.2012 09:25:27 ChangeUserPref BrowserFolders,
06.02.2012 09:25:27 ChangeUserPref SessionQueries,
06.02.2012 09:25:27 ChangeUserPref ExternalTools,
06.02.2012 09:25:27 ChangeUserPref Documents,
06.02.2012 09:25:27 ChangeUserPref Reports,
06.02.2012 09:25:27 LogonHistorySave end
06.02.2012 09:25:27 FormCreate Session.Connected
06.02.2012 09:25:27 FormCreate Logon.Executed 0
06.02.2012 09:25:27 FormCreate TDBNames.Make
06.02.2012 09:25:27 FormCreate SessionChanged
06.02.2012 09:25:27 SessionChanged SetDBAViews
06.02.2012 09:25:27 SessionChanged Authorizations.Load
06.02.2012 09:25:27 SessionChanged EnableAuthorizedMenus
06.02.2012 09:25:27 ExecuteConnectScript starts
06.02.2012 09:25:27 ExecuteConnectScript ends
06.02.2012 09:25:27 SessionChanged LoadRecentObjects
06.02.2012 09:25:27 SessionChanged Notify children
06.02.2012 09:25:27 SessionChanged Logoff secondary sessions
06.02.2012 09:25:27 SessionChanged SessionMode = smMulti
06.02.2012 09:25:27 SessionChanged EnableChildFunctions
OracleHomeKey: SOFTWARE\ORACLE\KEY_OraClient10g_home2
OracleHomeDir: C:\oracle\product\10.2.0\client_2
Found: oci.dll
Using: C:\oracle\product\10.2.0\client_2\oci.dll
06.02.2012 09:25:27 SortPreferenceSets
06.02.2012 09:25:27 - Default jammoh12035
06.02.2012 09:25:27 - System Default
06.02.2012 09:25:27 FormActivate start
06.02.2012 09:25:27 FormActivate end
06.02.2012 09:25:27 WMUpdatePopups starts
06.02.2012 09:25:27 LoadFileList: C:\Users\JAMMOH~1\AppData\Local\Temp\5\PLS-Recovery\*.cfg
06.02.2012 09:25:27 LoadFileList 0 items
06.02.2012 09:25:27 LoadFileList DateSort
06.02.2012 09:25:27 LoadDesktop starts
06.02.2012 09:25:27 DoUpdateChildList
06.02.2012 09:25:27 LoadDesktop ends
06.02.2012 09:25:27 WMUpdatePopups ends
I see that access violation occurs during logon. I see that you are using an Oracle10gR2 client. Can you update to an 11g client and try again? I'm not sure if 10.2 is certified on Windows Server 2008.
We upgraded to PL/SQL Developer 9 and Oracle Client 11.2. However, we were still getting the error. I discovered that PL/SQL Developer was still using the path to the Oracle 10 client. Setting the system variable ORACLE_HOME had no effect at all.
Under Tools->Preferences->Oracle->Connection I set Oracle Home to the 11.2 client (C:\app\Administrator\product\11.2.0\client_1) for my user and not the system default. However PL/SQL Developer still has several things set to the Oracle 10 client as you can see in the support info below.
Is there a simply way of telling PL/SQL Developer were it needs to look for the Oracle cleint?
PL/SQL Developer
Version 9.0.0.1601
01.71861 - 100 user license
Physical memory : 4.193.848 kB (2.609.088 available)
Virtual memory : 2.097.024 kB (1.873.620 available)
Parameters
Preferences
Session mode: Multi
OCI Library:
Use OCI7: False
Preference Files
Plug-Ins
Aliases
eboxfdb-live
eboxfdb-test
fodbd3_P.world
fodbd3_T.world
fodbi3-live
fodbi3-test
Homes
OraClient10g_home2 (C:\oracle\product\10.2.0\client_2)
DLLs
TNS File
C:\oracle\product\10.2.0\client_2\Network\Admin\tnsnames.ora
Using
Home: C:\app\Administrator\product\11.2.0\client_1
DLL: C:\oracle\product\10.2.0\client_2\oci.dll
OCI: Version 10.2
Oracle Database 11g Enterprise Edition Release 11.2.0.2.0
Character Sets
Character size: 1 byte(s)
CharSetID: 31
NCharSetID: 2000
Unicode Support: True
NLS_LANG: GERMAN
NLS_CHARACTERSET: WE8ISO8859P1
Perhaps you are using an Instant Client? In any case, you can go to Tools > Preferences > Oracle / Connection and enter the full path to the oci.dll file of the 11g client in the "OCI Library" field.
