7.1.2.1326 HTML Help Window Bug
-IceTea-
When in the HTML window help and using the internal HTML viewer, the CTRL+F (Find) shortcut does not work at all when there are no windows opened in PL/SQL Developer, when there are, it actually opens the find window for the underlaying SQL windows and not for the HTML window, so you can't search the help text.
When not using the internal HTML viewer (meaning, using internet explorer etc.) after doing CTRL+F and searching for something, exiting from internet explorer's search dialog via escape or just closing the search dialog at the X hides the HTML Manuals window - very annoying. This is why I switched to using the internal HTML viewer, which is not better (as written above).
Neat. I come back from vacation and there's a new version! I like that! :)
Seems like my old topic about this problem has been lost in the sands of time. In it I told of 3 problems.
One has been fixed in 7.1.2 - the HTML help window maximization problem.
Second is described here by the author.
Third is lost, so I'll tell of it here: when you use ALT+TAB to switch between HTML help and main window, the HTML help window sometimes disappears from the window list, making you switch to a completely different window than indtended. Links to screenshots are below:
Screenshot 1
Screenshot 2
Screenshot 3
