I have a brand new windows-7 machine that I am trying to load PL/SQL Developer Version 9.0.1.1613 on.
When I try to connect to a database, I get the following message:
$ORACLE_HOME/bin/oci.dll
make sure you have 32 bit Oracle client installed.
Is there a work around or patch I can use to get Developer working with 11.2 Oracle client?
Frank
PL/SQL Developer
Version 9.0.1.1613
01.75834 - 1 user license
Physical memory : 4,066,248 kB (2,585,436 available)
Virtual memory : 2,097,024 kB (1,956,000 available)
Parameters
C:\Program Files (x86)\PLSQL Developer\plsqldev.exe
Preferences
Session mode: Multi
OCI Library:
Use OCI7: False
Preference Files
C:\Program Files (x86)\PLSQL Developer\Preferences\Default\Default.ini
C:\Program Files (x86)\PLSQL Developer\Preferences\mkeefsiegel\default.ini
Plug-Ins
*Active Query Builder (C:\Program Files (x86)\PLSQL Developer\PlugIns\ActiveQueryBuilder.dll)
*PL/SQL Documentation (plsqldoc) (C:\Program Files (x86)\PLSQL Developer\PlugIns\plsqldoc.dll)
*Red Gate Deployment Plug-In (C:\Program Files (x86)\PLSQL Developer\PlugIns\RedGate.dll)
*Version Control Interface 1.2 (C:\Program Files (x86)\PLSQL Developer\PlugIns\VCS.dll)
(* is Active)
Aliases
Homes
DLLs
C:\app\mkeefsiegel\product\11.2.0\client_2\bin\oci.dll
TNS File
Using
Home:
DLL:
OCI: not initialized
Frank
PL/SQL Developer
Version 9.0.1.1613
Parameters
Preferences
Session mode: Multi
OCI Library:
Use OCI7: False
Preference Files
Plug-Ins
(* is Active)
Aliases
Homes
DLLs
TNS File
Using
Home:
DLL:
