Conditions:
- Windows 10 64-bit, 2 monitors
- Some other programs are opened on both monitors
- PL/SQL Developer 13 beta 10 (also noticed in previous betas 8,9).
- PL/SQL Developer icon is pinned to the taskbar.
- Click on the icon to run and meanwhile continue to work with the other programs.
Effect:
PL/SQL opened somewhere on background (nothing but process existence in "Task manager" indicates this), a pinned icon on the taskbar does not show, that program already run. So, by clicking on the icon again, another instance of PL/SQL developer will appear. PL/SQL Developer connection dialog appears only when I minimize another programs. After selecting a connection of entering credentials PL/SQL Developer icon in the taskbar is active as it should be.
If you click on the pinned icon and wait for PL/SQL Developer connection window to appear (without clicking to focus on another program window), then after several seconds you'll get the connection dialog as it should be.
Effect:
