13.0.6 some (small) bugs
Thies
When using "Describe" on a mat.view (in another schema, with prebuilt table) I get the error "Object XXX has been deleted" but the popup is displayed correctly afterwards. For other actions like Properties or View/Edit no error occurs.
BTW: It would be great if ESC key can be used to close the popups (describe and properties) and return to editor.
The connections inside Preferences / Logon History / History are not displayed in Session/Set Main Connection or the connection selector per window.
