12c Features
cw2
Is there a version that supports Oracle 12c features? The issue I'm encountering currently is that the table editor does not appear to support identity columns.
You don't have to wait for Oracle 12.1.0.2 or the new PL/SQL developer for using Json.
Look for the excellent PL/JSON library on sourceforge and there you go: pl/json
Thanks Roeland. We can wait ... well, it's here ! ... and "other JSON libraries" were mentioned at UKOUG earlier this week. Including one that now doesn't work with 12.1.0.2 because the package uses what are now reserved words ...
I'd hate to work with a third party package, only to have to re-work when I upgrade the database :-(.
